TL-P vs TL-S head
TL-P vs TL-S head
Okay another question here, does anyone know if the head castings are the same on the TL-P and TL-S?
I know the cams, intake manifold, throttle body and some other things are different, but I wonder if the heads themselves are the same. Anyone here know?
I know the cams, intake manifold, throttle body and some other things are different, but I wonder if the head itself is the same. Anyone here know?
Cool, I kind of figured it might be. This is like the B16 head casting is the same as the Type R, but the Type R is ported and polished. I have thoughts of doing something similar when I get the cams...
Originally Posted by bigman
Damn, its amazing what i started months ago
On the way!
How can the increased compression ratio on the Type S be explained if the heads are the same?
Putting a "bowl" (machining more from a Type S head) would actually lower the compression ratio.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
'Big Daddy Diggler'
BTW, the Type S heads are different. If you change the pistons you will have to change the heads. You cannot put type s pistons in a regular TL's heads. Different part numbers. I have physically seen both heads.
oh and im thinking about pulling my heads off port matching every thing shaving the heads to increase compression ratio and type s cams and tb this winter
'Big Daddy Diggler'
Originally Posted by 1fasttl
Of course the piston's have different part number's cause the TL-S pistons are domed. Oh and yes you can put TL-S pistons on a TL-P. It will just raise your compression.
'Big Daddy Diggler'
Piston slap is caused by the bore on the block being to big for the bore size of the piston.
Yeah, that i know, having a Trans Am, that is a common Problem. I am going by what he said, since he has done the conversion before.
MetalGearTypeS
08-29-2016 08:28 PM
Eggs999bacon
09-24-2015 10:08 AM
