Tl-p
Old Oct 13, 2009 | 11:23 PM
3.56thgen's Avatar
Tl-p
did anyone do the six speed swap to a tl-p and if so what the rev limit stop at?
Old Oct 13, 2009 | 11:25 PM
Rockstar21's Avatar
The Dumb One
more and more people are doing the 6 spd swap lately...
but it only makes sense to swap out the motor to a Type S as well..
i want to say the 6 speeders are going up to 8-8500 rpms...?
Old Oct 13, 2009 | 11:43 PM
3.56thgen's Avatar
what is it!?
Old Oct 14, 2009 | 02:37 AM
01tl4tl's Avatar
look in the DIY 6 speed swap, by fsttyms1- his is an 00-p ~originally~
the trick with the swap is you lose the computer limited downshift rpm limits of the auto trans-
Many have missed 4th and caught 2nd at high rpm on the upshift, (BANG!)
or overrevved on a downshift (screech BANG!!)--
get these motors much past 7000 and expect internal damage from valve float and contact to piston
Old Oct 14, 2009 | 06:12 PM
DaveS221's Avatar
man each one of ur "bang's" made me cringe...
Old Oct 14, 2009 | 06:42 PM
Anotherguy831's Avatar
but if they did the swap with the complete cl-s 6 swap; that would elimnate that problem
Old Oct 14, 2009 | 07:34 PM
Rajca's Avatar
wham bam thank you ma'am
i went from 5-2nd at 85mph and it was bouncing off 9k for a sec. bent valves bc of that.
kris (from florida not mod) is using the tl-p engine and 6spd. he had a problem with his rev limiter, i believe hes using richies harness to fix the problem now.
Old Oct 14, 2009 | 08:22 PM
fsttyms1's Avatar
Ummmmm NO..............
Old Oct 14, 2009 | 08:23 PM
fsttyms1's Avatar
If you keep the auto ECU with the manual you will have the ECU not liking it and you will be restricted. You will want the Richie modules. Also be warned that until you use the modules you wont have a reverse lockout which could be a big problem hitting Reverse instead of 6th
Old Oct 14, 2009 | 08:24 PM
Rockstar21's Avatar
The Dumb One
so why not chime in?
did you not get the sense of unsure in my post?
hence the question mark after my guess
Old Oct 15, 2009 | 04:55 PM
fsttyms1's Avatar
Yes i got it, thats why i posted No.
Where did you possibly think the type-s motor would go to that (8-8500)? The 6 speed motor is the exact same motor as the auto type-s. 7000-7200 is it. The computer stops it from going any further.
Old Oct 15, 2009 | 05:03 PM
Rockstar21's Avatar
The Dumb One
i figured the 6 speeds may have possibly had a different ECU.
arent manual transmission cars that are coupled with a better engine(type-s) generally capable of higher shift points?
ie: AV6 5 speed auto vs. AV6 6 speed have same or different shift points?
i was just guessing
wasnt trying to spread false info... nobody else was answering so i took a shot
Old Oct 15, 2009 | 05:05 PM
Rajca's Avatar
in a manual u can shift up to 7200, same as my tl-s auto. 7200, but ur max whp is at 6700
Chojun
Dec 16, 2015 07:12 PM
SCEPTRE
Jul 2, 2005 10:54 AM
03CoupeV6
Apr 4, 2005 09:41 AM
ZeroPSI
Mar 14, 2005 10:42 PM
