Tire Pressure question....
Old 06-02-2001 | 02:12 PM
2K1NighthawkTL's Avatar
Question Tire Pressure question....
What tire pressure i should have set on my stock tires? When i got it, they were at 36psi. That is too high huh? I took it down to 32psi and it looks flat. What do you guys put? Thanks
Old 06-02-2001 | 02:35 PM
Post
Dont worry about the fact that they look flat; just make sure you have a reliable gauge, and they are kept at the recommended pressure. (Which is 32psi, btw)
Old 06-03-2001 | 12:11 AM
songoku's Avatar
BlingBling INSPIRE 32V
Post
Yeah....It's not gonna do anything if you go over 32 psi....
Old 06-03-2001 | 01:21 AM
UTChE96's Avatar
Exclamation
I go with 32 psi when my tires are hot. When I go over 32, the ride is too bumpy.
Old 06-03-2001 | 01:52 PM
Oswald Vater's Avatar
Post
When I got my TL in April, 2000, my salesman took air out each tire. He said they were sending them out too high from the factory. I would recommend starting with the pressures suggested on the door jam sticker. Then you can go a pound or two either way depending on whether you want a smoother or stiffer ride. FWIW - I run the recommended pressures, but I like a smoother ride.
udelslayer
1G RDX Problems & Fixes
05-06-2016 01:27 PM
mugen_kid
11-13-2015 11:38 PM
NBP_BALLER
09-23-2015 09:18 PM
CostcoFanAUS
09-18-2015 07:05 AM
HeloDown
09-08-2015 07:51 PM
Quick Reply: Tire Pressure question....
