Tire pressure
/etc/car
Tire pressure
The general consensus is to have 32-34 psi in stock tires...
However, how is this measured? Obviously if I lift the tire off the ground it would show a lower measurement because the weight of the car isn't on the tire...and the front tires support more weight than the rear tires.
Is there a "true" method of checking/inflating them?
SwampGas is correct, your pressure will always measure LOWER when you lift your wheels.
The reason is not so much weight, but the fact that the weight causes the tire to deform making the volume of the tire smaller. Less volume with same amount of air == higher pressure.
Measure your pressure with the tire on the ground.
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
