Tire inflation
Guest
Posts: n/a
Tire inflation
My husband checked the inflation on the tires on my type S and found them overinflated to 40 psi. The recommended psi is 32. By reducing the psi, the ride is much more compliant. Other than that, the car has been great!! You might want to check your tire inflation.
Guest
Posts: n/a
Thanks I'll check mine.
I still think there should have been electronic suspension adjustment button. My 3000GT you can switch between Sport and Tour. Tour mode gives you that smooth ride on the city roads but can switch to sport when you want to carve the road.
The dealer tells me that they put about 40+ pounds in the tires for the transporter ride to the dealership. This way, when they crank down on the tie downs, the tires don't compress too much. The dealer is supposed to correct the pressure prior to delivery. It's part of the dealer prep.
The "old" guy
Mine were at 36 and 37.....now all at 34 as I run a lot of highway. BTW...if you missed my post somewhere else, I got 30.1 mpg running at a steady 82 miles per hour coming back from Lake of the Ozarks last Sunday.
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1609938&a=12281549&f=0
72" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1609938&a=12281549&f=0
72</A> Olds 442 Convertible (dual ram air) Play ride
99 Chevy Explorer high top conversion (vacation ride)
80 Honda CB750F (Shoei/Kerker) wheelie ride
02 TL-S Black/Ebony Underbody/spoiler/wood MY RIDE
00 John Deere 4 wheel steer (yard ride...hehe)
I finally checked my tires today and they were all at 41! I took them down to 34 and the ride is softer and the cornering is better (slightly). I am just wondering if the over-inflation helped or hurt the MPG. Anybody notice if their MPG changed after correcting the air pressure?
