Timing Belt service with Valve Adjustment...cheap!!!
Bump for Acuraziner....juanclopez2786....for doing a great job changing my Timing belt, Water Pump, alternator belt, ps belt, coolant, and valve adjustment for a discounted price. Old parts looked good so that's a relief. Coming up...ball joints and side mount....tokico blue with tein s-techs...possible rear sway bar???...
did they replace the timing belt pully and tensioner?
If not already done- seafoam it and new spark plugs- makes car like new
He didn't have to, they looked really good. Definitely did the sparkplugs at 120k and seafoamed twice through the tube that comes from the brake booster thing.
typically- not replacing the tensioners is suicide in 20-50k miles
A; they are old and critical!!
B; tension has been removed then more tension applied to those parts--not good for the springs inside
Replacement engine cost when tensioner fails and belt stops turning: you dont want to know~
Hey tlvet,
I did the same thing a while back. Didn't know to have the shop replace the tensioner and pulleys. I just finished replacing the engine.
https://acurazine.com/forums/2g-tl-1999-2003-98/timing-belt-melted-time-new-engine-737796/
How much did the valve adjustment cost? The shop I took it to was going to charge 4.8 hours of labor at $92/hr. I hope you got a better deal!
JR
JR
valve adjustment labor is a combined event when done at the 105 service
Some of the same parts are removed- otherwise its 4 hours by itself
iirc- its a about ~1.5 hours actual work to check and adjust- once you are at or inside the valve covers,,,then recheck and adjust as needed
3rd Gear
When I change timing belt, I alwasy change water pump, tensioner and idller pully, adjuster pully if exist etc..., all the accessory belts and also finsih adjsuting valve adjustment (since every things out any wasy to do this). This is agood insurance policy and good chance to make it another 100k miles.
asahrts
09-04-2015 05:55 PM
