Time to replace brakepads. What to get?
Old 06-26-2002 | 09:22 AM
enderwiggins's Avatar
Question Time to replace brakepads. What to get?
I really dont feel like i should be replacing the pads already. Ive got 16,600 miles on the car but recently it feels as though the brakes are jumping or worn. Also fading a bit. I figure all i need is just some new brake pads.
A question. Anyone here replaced their own pads? How difficult of a job is it? What kind of pads should i go with?
Old 06-26-2002 | 11:23 AM
rmarin2's Avatar
Re: Time to replace brakepads. What to get?
Before you go out and buy pads you should verify that you really do need them. My car felt the same way and when I checked to see how worn they were I was surprised to see I still had a lot left, and I have 20k miles on my car.
If it turns out you do need them, I suggest you just go with the OEM pads. Just my $.02 though.
Old 06-26-2002 | 11:34 AM
Check some Hawk's pads...
Old 06-26-2002 | 12:50 PM
WWW
Papa Bear
Your brake pads should last more than 16,600 miles, unless you drive like a mad man. I'm not sure what you mean by "jumping". But with my car at 12,000 miles, the front rotors warped. I took it to the dealer and they said they have a bulletin on that. They replaced the rotors and put in new pads all under warranty. You might want to try that first.
Old 06-26-2002 | 01:07 PM
I have 48 000 km so far on my 02 TL-S and no sign of wear from my brakes.
Old 06-27-2002 | 11:29 AM
thanks fo rthe replies, im gonna drop by the dealership at lunch.
Old 06-27-2002 | 02:40 PM
NsX Pilot's Avatar
Re: Re: Time to replace brakepads. What to get?
id try to replace them under warrenty due to this issue with the warped rotors also but if there not gonna budge then i sugggest using axxis brake pads
Old 06-27-2002 | 02:58 PM
Went to the dealership at lunch. Front rotors were slightly warped, They turned the rotors under warranty and now everything is good. No more fading or jumpy brakes.
Thanks for the help.
mada51589
05-03-2022 09:54 PM
csmeance
09-10-2018 10:15 AM
Skirmich
09-15-2015 07:41 PM
V12 Inspire
09-10-2015 05:46 PM
asahrts
09-04-2015 06:55 PM
