Throwing codes after 440cc fuel injectors
Okay so I've installed RC 440ccs yesterday and came back with 3 codes, the first two were obvious P0172 P0170 (fuel too rich), but what I'm having a problem with, is code P0113. Now I've googled it and it says the IAT sensor is either damaged or has no resistance to due low temperature.
To those who've had this problem, would P0170/2 cause the IAT to malfunction? I want to get this car on the dyno and tuned, but it's running in limp mode right now. Would tuning the car to run optimal get rid of P0113 and get me out of limp mode?
injectors new? installed properly no leaks? You install them? Do you smell fuel? did you lubricate the o-rings before installing them? every thing plugged in?
Like a BOSS
on top of that make sure your IAT is not broken, and make sure its pluged in if it is pluged in disconnect it and make sure no oil/dirt/water got into the connector, clean it out and apply some dielectric grease for good measure
Jamus22
06-11-2023 10:08 AM
