For those with Zex Nitrous
Acura TLS are SLOW
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
How did you hook your Zex nitrous kit up. I dont have the Helms manual so Im trying to find the Throttle Positioning Sensor. Which wire do I tap in for the nitrous. And does the nitorus cut off when i hit the rev limiter on SS mode?
Thanx
Stan
Thanx
Stan
the TPS is on the throttle body directly across from where the throttle cables connect. there should be 3 wires going to the sensor. the middle wire should be red/black, that's the wire to tap.
i'm not sure if the nitrous cuts when you hit the rev limiter. it might be a good idea to call the zex tech line and find out.
Acura TLS are SLOW
Stan
jermz123
03-10-2005 11:03 PM
