Temperature control...
Old May 25, 2004 | 05:39 AM
gregtomash's Avatar
Let me describe the situation... It is a somewhat cloudy day, 60F - 65F outside, and your climate control is set to about the same temperature. Then the sun comes out and, all of a sudden, air conditioning starts blasting very cold air as if the temperature inside the car went up to 80F! Usually, I have to re-set the temperature to 72F - 73F, if I don't want to freeze to death. Apparently, something is wrong with the temperature sensor. Where this sensor is located? Can it be cleaned? Does anybody know what may cause things like that? Please, help! :bowdown:
Old May 25, 2004 | 08:32 AM
fsttyms1's Avatar
unless im mistaken its right above your right knee (smal little vent looking thing about 1 inch long) as far as cleaning i doubt it.
Old May 25, 2004 | 12:27 PM
Severin's Avatar
I also thought we has a photosensor also to measure sunlight penetration into the cabin..?
Old May 25, 2004 | 12:56 PM
fla-tls's Avatar
On the way!
Yeah - the photosensor is the dark looking think on the center of the dash right next to where the windshield meets the dash. Mine does the same thing when I go from dark shade to bright sunlight.
Old May 25, 2004 | 08:10 PM
gregtomash's Avatar
Thanks guys!!! It looks like that the photosensor is causing the problem. Has anybody tried to do something about it - like disabling it by covering it with something dark?
Old May 25, 2004 | 08:49 PM
fla-tls's Avatar
On the way!
Hmm... For me, just knowing what was causing it and understanding how to work with it helped. It's a bit of a learning experience going from a totally manual car to an automated one. Next time you start up, try going a few minutes on full auto - and the temp set where you want it in the end (ie 70-75).
I think you'll learn (as I did) to stop trying to manually adjust it so much. It's a pretty smart system; you just have to be a little more patient after you start off. (like - the fan speed won't go up immediately, but takes a minute or so)
Old May 26, 2004 | 05:47 AM
gregtomash's Avatar
Thanks, Fla-tls! I guess, you right...
rockyboy
Aug 4, 2024 10:35 AM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Scottyknows007
Sep 21, 2015 01:03 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
Sep 17, 2015 09:01 PM
