TEINs stuck
2 of the 4 of mine were stuck also.
1) I tried to use both wrenches to turn it at the same time.
2) I also tried to set the wrench and hammer it.
3) Tried putting a flat head screwdriver in one of the sockets and hammering it.
4) I pretty much soaked it with WD-40.
5) I used a torch to heat up the rings (dont do this at home boys) that didnt work
One of the 2 stuck suspension, I used an impact hammer and FINALLY GOT THE DAMN TOP RING TO MOVE.
The second one was more stubborn, I ended messing up one of the sockets, and I got so fed up, so I used a grinder and cut the ring, I was then able to slighty pry it open and turn it.
Hope this helps! And hope you dont have to end up cutting the ring like I did!
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 07:42 PM
