TCS vs VSA
Not a Blowhole
They are very different. The TCS merely responds to a spinning wheel under 25 mph and brakes that wheel so the transaxle gives more traction to the wheel with grip. In VSA, there is a sensor that uses computer algorithms to assess the current state of the vehicle: Speed, steering angle, direction, yaw. It works at any speed and can alter vehicle dynamics to help maintain directional stability. It also can act as the TCS because it has the same programming needed to give traction by wheel braking. So it is a much more sophisticated system that does double duty.
Rage On!
2000 TL w. Comptech header/exhaust
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Fender lips rolled
Rage On!
SSR Integral A2's
17x7 45mm offset
Fender lips rolled
Call me oblivious, but even when the TCS light is not on without pressing the button, it kicks in when slippage occurs. So does that mean it's on all the time? Or do you have to press the TCS key and have the light on for this system to be on all the time? I can't figure it out. Do you get worse gas mileage when the TCS is on all the time?
Thanks if you can help ;-)
By default, TCS is ON when you start the car. When the system is ON, the TCS light on the dash is OFF. When you press the TCS button, the light on the dash comes ON, meaning the system is OFF. However, with the system ON, if the TCS indicator comes ON (it'll be intermittently) then TCS is at work... the indicator shows you it's actively enhancing your traction.
It does seem somewhat counterintuitive at first, but I see what they were going after. Personally I like it this way better -- I'd rather see dash indicators illuminated only when there's an abnormality (i.e. when the TCS is the sysworking, not just whenever tem is ON). Imagine the SRS light staying on all the time letting you know that the airbags were working OK and you'll catch their thinking.
2000 WDP 3.2TL non-NAV
However, why would Acura give us the option to turn off TCS? Doesn't make sense unless you get better gas mileage? Any thoughts anyone?
Jamus22
06-11-2023 10:08 AM
