Swaybars
Swaybars
I just got Eibach sways installed. If I could do it over again, I would've made this my first mod! They make a HUGE difference in handling.. less understeer, turns are much sharper, and body roll is a lot less pronounced. Some stiffer springs will really make the handling/ride perfect.
you mean less oversteer?
and yeah, sways are a cool mod, the car wont beel like a boat no more...go for a strut and springs too and you'll feel like driving a race car...but when your cruising it will feel as gentle as its always been.
Originally Posted by IndyTypeS
how much did you pay for the eibachs?
Originally Posted by PenguinQX
From what I heard, the strut bar doesn't do much. I'm not familiar w/ the CUSCO.. can someone explain what that is?
Originally Posted by moahdriven
CUSCO or Neuspeed strut bar? which u guys recommend?
Neuspeed...WHY? Because it's...
#1 Cheaper
#2 Single piece
#3 Looks OEM
The CUSCO bar is almost twice the cost of the Neuspeed...PLUS it's a 3-piece design. There should be tons of threads about this (I know I've participated in many), but the consensus is that multi-piece ANYTHING generally allows more flex than single piece braces.
Personally I like to stick as close to OEM as possible, so #3 is based on my opinion.
Originally Posted by SilverIce2000
anything wrong with gettng used??? i know comptech is good, but is the titanium a differnet type???
the sway bars are installed under the car
for the money, I'd recommend keeping the oem strut bar and put an upper tie bar...I did it and I noticed a good difference, plus it looks cool when you lift the hood. I agree with fsttyms, you'll get more from sways and lowering if you have the $$
The strut bar is pretty pointless for a our cars. It really depends on the driver, I guess. It creates much more stability towards the front(where most of the weight is already) causing more front-end traction, but more slippage in the rear.
I agree with swaybars being an excellent modification. I put CT sways on right after my coilovers and my cars just hugs onto tight turns. Definitly worth the investment.
a1ex
07-06-2006 08:18 PM
