Swapping a 6 speed into an 03 TL Type-s
OM NOM NOM NOM
1 Post
Has Anyone done it? I was wondering how much labor usually costs and what other parts i need to buy. I'll be stripping a 6 speed from an 02- CL-S that i found from the wrecking yard. Getting it for a pretty good deal too, including the computer, the harness and everything. I need some guidance though, so maybe some of you guys can help me out.
the 6 speed only came in the 03s and check the sticky on the top of the page.
OM NOM NOM NOM
1 Post
I Saw the sticky, but you also gotta consider the fact that he swapped out his regular motor for the type-s motor. What I was wondering is if you were doing a cl-s swap to a tl-s what other parts would/might be needed. I wanna know so i know what to buy
No He Can't
What about that little part where you have to get a bunch of connectors that were only on the manual?
Originally Posted by fsttyms1
*If you use the J32A2 from the Auto you will need these parts (all from the CLs-6)
Front cam pulley 14260-PGE-A11
Front plate assembly (behind cam pulley) 11860-PGE-A10
Timing belt pulley(lower) 13621-PGE-A11
Crank shaft sensor 37500-PGE-A11 (this little shit costs $500.00)
Subharness for CKP 37501-PGE-A10
TDC Sensors (Qty 2) 37840-PGE-A11
TDC SUB HARNESS 37841-PGE-A10
OM NOM NOM NOM
1 Post
Originally Posted by o2cls
Fawk....I hate 20 yr olds.
mrkingstonvi
02-22-2016 01:53 PM
LECKEY73
02-22-2016 01:32 PM
handsom-hustla
11-13-2015 05:04 PM
Skirmich
09-15-2015 06:41 PM
