Susspension Mods, need some info
I want to lower my car 1", no more than 1.5 and also stiffen up the body roll problem, What should i get. THere is so many different suspension parts out there, I have no idea where to get started
That is too much I think
Is that going to mess my alignment up at all, will the car still be able to be aligned correctly???
Also, 1.75 is more than I had hoped for... I was looking for 1.2-1.5 I dont want to be bottoming out at all or sacrificing the smooth ride I have right now...
Re: That is too much I think
Lowering Springs
Your have two options IMHO:
1. You could go the coilover route so you can adjust your height. Cost can become a major factor for a good coilover setup.
2. If you just want a 1 inch drop and want to save money...I would look into H&R O.E. springs. They drop your ride about an inch front and rear, Or you could step up to the sport springs from H&R which will drop your ride aprox 1.75 in the front and rear. The best thing is that they run aprox 170.00 bucks for the springs....
Good luck
Good luck
MrHeeltoe
20
02-23-2023 01:54 PM
InFaMouSLink
10-27-2015 06:52 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
