sunroof wont close all the way
sunroof wont close all the way, closes about 90 percent, then just comes to a stop... dont hear the motor going after that.. it just completly stops.. checked the tracks and everything and nothing is in the way... it was working perfectly before hand.. what happened? and how can i close it.
In the trunk with the lug tool there is a S shaped small wrench. That is to manually close the roof. In the back seat there is a round plastic plug in the headliner. Put a screw driver or dime or whatever in the slot and turn it 1/4 (maybe 1/2 dont remember) and pull the plug out. The tool fits in the opening and you can manually turn it. See if you can close it by hand. If so try opening and closing it with the switch again and see if the same thing happens.
thanks for the info.. tried that and didnt work... so i checked the track on the pass side and one of the metal things was pointed into the way of the track so i pushed it back and tightened it and the driver one too and turns out that was blocking it... thanks for your time
J/k Glad you got it figured out.
yeah, got to check all the screws now and then, clean the drain tubes, lube the track--spring cleaning is in session
thanks for the info.. tried that and didnt work... so i checked the track on the pass side and one of the metal things was pointed into the way of the track so i pushed it back and tightened it and the driver one too and turns out that was blocking it... thanks for your time ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
same thing happened too me more then once. only thing is it happened on my drivers side.
mlody
12-04-2019 02:11 PM
