stock suspension
stock suspension
is the stock suspension on the tl-p the same as the one for the tl-s? acura's website wasn't informative on this issue. i want to up my stock 16" wheels to something similar to the stock 17" setup on the tl-s without changing the suspension.
if i did this, would i have the same suspension/wheel/tire setup as the tl-s?
thanks in advance.
thanks in advance.
Retired MOD
1 Post
Re: stock suspension
thanks in advance.
thanks in advance.
I'm not 100% sure, but the TL-S springs have a higher rate. About the height, I'm not sure.
If you change from 16" to 17" you will have a very similar look to the TL-S. IMO I would go with 18".
thanks for your replies.
it seems therefore that acura did not do much to improve the tl-s' handling over the tl-p besides simply beefing up the wheels and adding a thicker sway bar. i wonder if this is sufficient for the added performance of the tl-s.
can anyone with 17's on a tl-p stock suspension comment on whether their ride height/wheel gap is virtually identical to the tl-s?
in japan, ride height is such an important issue 'cuz of parking. many of the parking lots here operate as "car elevators" where your car gets stacked into a large elevator bay. each elevator platform is shaped like a "W". if your car is too low, it won't fit most of the "W" shaped platforms. that blows. the metered parking lots are even stranger. your car sits over a "bump" which elevates a horizontal plate to roughly 45 degrees so you can't drive out unless you feed the meter which lowers the metal plate. driving in tokyo is such a pain in the ass.
Retired MOD
1 Post
BlingBling INSPIRE 32V
Originally posted by just_a_tl
only difference the tls has is the 17's and 1mm thicker rear sway bar. shocks/springs are exactly the same
front shocks/springs
different part #s, different prices = different parts (maybe??)
Mr. Self Destruct
I was under the impression that the TYPE-S had stiffer springs. I'm not 100% sure what Acura means by "Sport Tuned" but I have heard people say the Type-S' ride feels more tight/stiff after driving both. Some even go with the TL-P because they don't like the added stiffness.
Eyeballing the height, they look they same.
Originally posted by songoku
Do you know TL-P front coil springs cost almost 3 times more than TL-S front coil springs???
:wow:
:wow:
In any case, this is an interesting thread. While looking for lowering springs, I rode in another a-tl member's TL-S with Comptechs. I can't imagine the ride in my TL-P with the same Comptechs would be terribly different, despite the difference in wheel size (16" vs 17"). Or would it? After all, the two cars are nearly identical except in wheel size, rear stabilizer bar, engine output, and silvered dials.
Appointment for springs installation is in three weeks, after I come home from an out-of-town trip! New rubber to follow...
i was looking at the part #'s and they were all the same. not sure...
i measured the high of both cars and they were identical
02 TL-P 51401-S0K-A12(front) 52441-S0KA02(rear)
02 TL-S 51401-S3M-A02(front) 52441-S0KA51(rear)
Originally posted by neuronbob
Eh? Is this true? I would think it'd be the opposite.
(Only front springs have price difference. Rear ones are same even though parts #s are different.)
4drviper
09-23-2015 07:42 PM
