Stock Sub with Aftermarket Head Unit
Can I use a speaker level converter so that the stock sub and stock amp work with the aftermarket head unit?
https://cimg2.ibsrv.net/gimg/acurazi...2d78dccd58.png
The signal to the factory sub woofer amplifier is a preamped/low level signal. What ever signal going into the factory sub woofer amplifier should also be preamped/low level. Unless you connect a amplified/high level signal straight to the woofer. |
