Stock HiD Problem
Stock HiD Problem
So anyone else experience the same frustration I am? Stock HiD Headlights are always off on one side.. Anyone have a solution? One side is yellow the other side is HiD quite anooying.
06 NBP 6MT TL
Dude you're gonna have to say that in English haha. So is it the same side that doesn't come on, or does it alternate? Do both of the bulbs match? Sounds like you need some new bulbs my friend.
Yeah, ya could try swapping sides if one side is known good......otherwise replace both with new ones as Cincinattiguy19 previously advised. Check the connections for signs of moisture or corrosion.....if so, then consider one of the aftermarket replacement kits for our HID low beams.
i swapped the bulbs and then the opposite side turned yellow like before the drivers side was yellow, and the passenger side was blue, after swapping the bulbs with brand new ones the opposite happened the passenger side turned yellow & the driver side turned blue.
tman570
06-11-2019 07:56 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
