Stock HID help
Read THIS
Well today the 6000K DS2 came in and I put 'em in. The lights are just great, when you turn them on they were purple and then turned into blue. There were a bunch of kids playing in front of the car and they all went "OOOOOhhhh!, AAAAhhhhhh!".
Although when I recieved the bulbs the casing (insulation?) around the wire that is parallel to the bulb had a crack in it at the base of the bulb. My neighbor said that its ok since the casing is still around the wire and the light did work after I plugged it in. Should I be worried?
And another important comment, when I had my 4300K I bought Solaris hibeams, and they had a more of a blue color than my stock HIDs, now they are yellow (or they seem to be since the HIDs are blue) I spent like $70 on them, what should I do, should I glaze the bulbs with some thin blue marker/paint???
the high beams are regular halogens, you can't give them a bluish glow without buying something like PIAA hyperwhites or whatever (the cheap bulbs burn the blue off quickly).
definitely don't put anything on the bulb surface, you can't even put a finger print on them; it'll decrease their life significantly.
Re: Read THIS
and fyi, with 6000k you will never ever be able to match it with any halogen, it's just too much for the power of halogen to match. you either go with hid high beam (which i think is unnecesasry) or you forget about it. i forget about it coz' i hardly use it except when i flash people
that's simply when i threw away my old fogs and got 6000k hid for it as well
Re: Read THIS
where can i get 6000k hid and can i get them for a 2000 tl?
BlingBling INSPIRE 32V
For now, I'm mostly worried about the cracked insulation...any comment on that?
Spoke with J. Lui at SUV lights about my bulb problem. He said that the purpose of that covering/insulation over the wire serves as "a anti reflective surface so it does not affect the function of the bulb" He said that some people crush it and remove it to get more light and color but he doesn't recommend it.
If anyone is looking to buy 6000K I'd recommend him due to his service.
