Steering Wheel shaking
Old Oct 4, 2001 | 08:53 AM
DragonTls
Guest
Posts: n/a
Angry Steering Wheel shaking
I know that the tls has bad brakes, but this sucks big time. Any of you out there experience this and what did you do about it?
I have brand new tls and when I'm traveling between 60-80 mph and hit the brakes the steering wheels shake like I have warp rotors. Did I get a defected vehicle or all tls does this.
Old Oct 4, 2001 | 09:45 AM
rockinTLS's Avatar
Sounds like warped rotors.
One thing to check is lug nut torque. If you have had the wheels off lately, especially if a shop did them, it's possible they over torqued the lugs. If they used an impact wrench, its a very strong possibility. Retorque them by hand and check again.
Otherwise, either you have been pretty hard on the brakes or are like others who have experienced defective brake pads that overheat the rotors and cause this problem.
If the car has low miles, many times the dealer will fix the problem under warranty. Try them.
Good luck.
Old Oct 4, 2001 | 12:33 PM
BakedWafer's Avatar
Grand Turismo
Rotors
Sounds like warped rotors to me, take it in and get it fixed.
Old Oct 4, 2001 | 01:45 PM
gohawks63's Avatar
Re: Steering Wheel shaking
This is a known problem and there's a service bulletin out on it. Take it in, they should replace your brake pads and replace (or resurface) the rotors.
If the warpage is not too bad, they may just resurface them, but I'd try to fight to get new ones.
They resurfaced mine, but I didn't make a big deal about it. I kinda wish I did.
Old Oct 4, 2001 | 06:41 PM
2K2SilverTL-S's Avatar
AZ O.G NoOldManVetteOwner
Yup, had the same problem. I had my front brake pads changed and my rotors resurfaced at 5000 miles, all under waranty.
Old Oct 4, 2001 | 06:48 PM
Mr Hyde's Avatar
I agree sounds like warped rotors, and overtorquing the lug nuts is a very common yet often over looked cause. Take the car to the dealer they should resolve the problem.
Old Oct 4, 2001 | 07:34 PM
RedLined's Avatar
Mine is doing the same thing (I now have over 20,000 miles on my TLS). I plan to take it in next week for service.
You may want to search for my previous post (titled "Wobble in my wheel") about a week ago on the same subject.
Old Oct 4, 2001 | 11:16 PM
ACURA TYPE S CL's Avatar
maybe your rims out of shape or your rotors.good luck.drive safe and careful
Old Oct 5, 2001 | 01:21 AM
evolaerok's Avatar
Wow to think I just ignored this problem and thought it was part of the "bad" tl-s brakes.....
Old Oct 5, 2001 | 10:23 AM
DragonTls
Guest
Posts: n/a
Thanks guys
I'll keep all of you post it with what happens...
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EvilVirus
Dec 10, 2015 07:38 PM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
