spray paint
spray paint
does anyone know of a silver aerosol paint that would match the satin silver. i know i could do it the trial and error way but id like to know if anyone knows of a paint thats and almost match to our ssm. have a project in mind and id like not to spend too much money. thanks in advance
theres a website that will color match your factory color code and put it into a spray can, i forgot the name. Someone will give it to you, thats gonna be your best bet
k thanks. i think i found it but not sure. the site is www.expresspaint.com. lmk
You dont even need the internet
Get out the phone book yellow pages for auto paint supply stores
They supply all the local body/paint shops
Give them the paint code and they will put it in a spray can for you
If you are looking to shoot the engine cover- most paint shops will do it for 20 bucks
also you can buy auto paint in raw form (by the pint,quart etc.. (just ask them to reduce it for you) and use this to spray it
https://acurazine.com/forums/showthr...ighlight=paint
http://www.paintscratch.com has paint that's a good match for SSM. I painted my mudflaps with their paint and the match is great.
I just visited the paintscratch website. I have a couple of question about the whole touch up process. I have a couple of scratches all the way across the back section of my trunk down to the primer of maybe even the sheet metal. So to repair this I would use the wax and grease remover, then the Base Coat, Mid Coat, Clear Coat, Finally rubbing compound. How do you know when the blend is good? Just wanna know if there are any techniques recommended as I know nothing about this whole touch up process. Thanks
You will know when the blend is good when you have a hard time seeing it. Sometimes it helps to build the area up higher than the original and wetsand it down and smooth. then polish the area out.
Kris- do you know places that charge less? or am I getting a deal because I drop stuff off at lunch when its hot and bring popsicles for the shop ($2) and return the next eve with cold beverages?
Build Up
When yo say build up do you mean put an extra layer of clear coat. Finally you use the rubbing compund with the wetsand?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
