Spc Rear Camber Kit Install
Old 05-17-2003, 02:38 PM
kman156's Avatar
Thumbs up Spc Rear Camber Kit Install
OEM CRAP!
Old 05-17-2003, 02:40 PM
kman156's Avatar
Thumbs down OEM CRAP
PIC 2
Old 05-17-2003, 02:42 PM
kman156's Avatar
Thumbs up NEW SPC REAR CAMBER KIT
SWEET! p.s. purchased from acura-tl.com! tim got me a special quick order, when i needed it fast , and it was out of stock!!! thanks bud!
Old 05-17-2003, 02:44 PM
kman156's Avatar
LAST TOUCH, A NICE
ALIGNEMENT!
Old 05-17-2003, 02:45 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Looking good...
Old 05-17-2003, 02:58 PM
kman156's Avatar
Exclamation thank you brother neil!
some more goodies next week! stay tuned oh, and my big mystery mod soon!
Old 05-17-2003, 03:43 PM
NSXNEXT's Avatar
Re: thank you brother neil!
Hey slow down...I can't keep up this pace.
Did you check out my post about the SSM trim pieces?
Old 05-18-2003, 12:11 AM
UA5-TL's Avatar
oh i need a pair of those too!!!
Old 05-18-2003, 01:43 AM
Blown is Best
Allout's Avatar
Good choice. I've got SPC kits on the front and back with no regrets. Tires are wearing perfectly and at $850 a set, that's saying alot.
Old 05-18-2003, 02:15 AM
kman156's Avatar
Exclamation gonna do the fronts too!
when you drop the car, and after the springs settle, at least i found, it can cause the car to start pulling. my next set of rubber will be like 8-1,000 a set as well! plus i'm still running excelllent bridgey re730 potenza's. gotta keep her riding on rails!
Old 05-18-2003, 04:26 AM
AcuraTLFan's Avatar
Hey kman, what was the process of aliment and camber adjustment? They put ur car on the machine...they measure...they jack up car and adjust camber, they keep doing this till it's perfect? Or do they do it some other way?
Old 05-18-2003, 11:19 AM
VTECRRR's Avatar
basically, except
the car stays on the lift as the camber is adjusted. my bro was adjusting the camber as i was reading the computer and yelling back to him when the camber display was lined up even /centered in the green on both sides! then the toe and caster just fall into place as that degree adjustment is done and the alignment is fine tuned.
Old 05-18-2003, 03:55 PM
Blown is Best
Allout's Avatar
Re: gonna do the fronts too!
I've got the RE730's on my ZX and love them. How are they on the TL? I was concerned that the tire would be too noisy for the TL.
Old 05-18-2003, 06:23 PM
VTECRRR's Avatar
Thumbs up supergrip! noise?
between the i/h/e and the boomin' system! i couldn't even tell you if they make noise
Old 05-19-2003, 02:13 PM
AcuraTLFan's Avatar
How are you suppose to adjust the fronts?
Old 05-19-2003, 08:14 PM
Blown is Best
Allout's Avatar
The SPC kit replaces the upper ball joint and the new one is on a slotted sliding bracket. Loosen 1 nut and adjust.
Old 05-19-2003, 10:38 PM
AcuraTLFan's Avatar
Sorry, what i meant was, how are you suppose to adjust them and measure the camber at the same time? If the car was already on the lift and the camber being measured...then wouldn't the car need to be jacked up and then adj.. they lowered and remeasured?
Old 05-20-2003, 02:41 AM
hellas's Avatar
when the car is on the alignment rack, its jacked from the suspension, not the frame. so the car is up in the air, but the suspension thinks its on the ground. ya know?
Old 05-20-2003, 07:40 AM
VTECRRR's Avatar
Exclamation YES!!!
YOU ARE CORRECT SIR!!!
Old 05-21-2003, 03:50 PM
Bfor3's Avatar
SPC?
were you able to get back to normal tire wear front+back??? I'm waiting on my rims to come in 2 days and definatly need even tread wear!!!! SHOULD I TAKE THE CAR TO ANYWHERE FOR THE ALIGNMENT, THE DEALER DOES ALIGNMENTS SHOULD I TAKE IT THERE? HELP PLZ
Old 05-21-2003, 04:25 PM
Flyin' and Drivin'
Comet2404's Avatar
<---sigh.... I need a right shock, and a right strut, and a new set of tires. These stock michelins aren't cutting it.... I had potenzas on my I30.... but I cant complain, she still handles incredible well.
james357
02-13-2016 02:37 PM
o8 ENVII 8o
11-30-2015 04:23 PM
IIDXholic
10-08-2015 07:53 AM
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Spc Rear Camber Kit Install
