SOMEONE please help me(its an easy question)
how the hell do you take off the tail lights? i want to darken tehm and also when i spray the window int stuff on it do i spray the inside or the outside? please reply
Sticky Rice OwnZ joO
1 Post
Open you trunk,
where the latch hooks on to the trunk, there are about 4 plastic screws.. take those off along with the cover..
take out the anchors for the netting that are in the sides of the trunk walls..
pull the lining back,
use a 8MM socket wrench to undo the bolts holding the tails in, detach the wiring harness or unplug the bulbs..
Originally posted by shloma
ok theanks man but also when i am spraying on the tint stuff on my tail lights to darken them, do i spray the inside or the outside?
you spray the outside of the taillight over the orange. but why would you paint the inside tho?
