Smooth idle?
Old Nov 21, 2001 | 10:17 PM
initialD's Avatar
Smooth idle?
Do we suppose to have very smooth at idle with our TLs?But i can feel there is some vibration every second(just like heartbeat)Is that normal?Anyone else has the same problem?
Old Nov 22, 2001 | 12:25 AM
daverman's Avatar
Yes, this is normal. I feel a slight "loping" motion too. I wonder if it's the fluid-filled engine mounts allowing the engine to rock back and forth periodically.
Old Nov 22, 2001 | 07:44 AM
ChucksCL-S's Avatar
My oo' TL does that too sometimes, but it goes away after two or three lopes or cycles.
Old Nov 22, 2001 | 09:30 AM
HU's Avatar
HU
I have a 2000 and it does that as well. I guess it is normal.
Old Nov 22, 2001 | 11:58 AM
initialD's Avatar
I had an Integer and the idle was like sleep,very smooth.Acura dealer said because it is a 4 cylinder engine.But i heard that Accord V6 also has very smooth idle.Is that true?
Old Nov 22, 2001 | 02:08 PM
Severin's Avatar
If the "loping" motion is a slight forward movement when your idling, in drive, with your foot on the brake, it's your air conditioning compressor clicking cycling on/off.
The engine compensates for the compressor's load by increasing the idle speed. I have noted that my brake pedal gives a little (pedal falls); I'm not sure why (vacuum change?)...
Old Nov 22, 2001 | 05:32 PM
daverman's Avatar
Nope, it's not the compressor (it feels different). The loping motion occurs without an audible change either. It just feels like you're in a boat rocking back and forth very slowly on the water.
Old Nov 22, 2001 | 05:41 PM
Shoofin's Avatar
Well, in warmer climates, your car will run more smooth, as the engine warms, especially...usually when the A/C complressor is on, it may run a drop rough, due to the added stress on the engine. Same thing applies to the winter time...the engine almost always runs a drop more rough(lil more vibration on the steering wheel than usual) than any other time of the year.
Ed
Mike734
Dec 10, 2021 01:25 PM
DerrickW
Nov 15, 2015 05:52 PM
012TL-GLM
Oct 5, 2015 06:32 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
