small problem with my tl (A few actually)
K-Fed's Stunt Double
Hey guys, been a proud TL owner for a bit I just have a few questions:
1. My radio is not turning on anymore (Stock bose HU not turning on at all) but the instrument panel is powered and everything else is fine, where can I see if the power wire for the HU is plugged in properly?
2. I have some slight rubbing on my 02 TL - S with my Advan MOdel 5 which are 19x8 with a 45 offset. It's moreso the front when I turn I hear a little rubbing, how do I fix this?
3. My advans have some chips on it (Gunmetal) how do I get them repainted
deal with it
1-check your fuses......to check the plug you have to pull out the hu.....i doubt its the plug if you haven't removed/played with the hu recently......if your hu turns out to be broken though let me know i have my stock one for sale.....
2-check the inside of the wheel well and see if its something you can remove then remove it.....
3-you would to talk to a wheel repair shop.....
2. What Is The Size Of The Tires You Are Running? Maybe You Are Catching On A Fender?
3. How Big Of Chips Are They??? U Might Get Them Off If They Are Not Too Big With A Degreser Or Somethin Gof That Kind.
what are the tabs?
it's on the front wheels, it's mostly when i turn, i'm thinking hte camber will fix most of that due to the misalignment of my drop
noentheless rims aregreat just gettin em fixedu pis scary
CheeseyPoofs McNut
10-11-2015 11:25 AM
pistacio
09-26-2015 09:45 AM
brandnewcolony
09-12-2015 10:39 AM
