Simple Problem
Simple Problem
I've just changed my front turn signals to hyper white...but for some strange reason...the left turn signal blinks twice as fast...I put on the hazard lights and it blinked fine. Is it the bulbs...fuse? I dunno...I mean...I know I got the right ones...because the numbers of the model match. 1157...Hybrid White. So any suggestions. When one side of the turn signal lights up brighter than the other what does that mean?
A faster blinking bulb usually is caused by a bad ground, I'd check the wiring.
Also, try switching the bulbs from left to right and see if it is the same problem. If the right now blinks faster it is the bulb and not the wiring.
SidhuSaaB
05-30-2020 12:40 AM
