Side view mirror realignment
Old 07-13-2002, 11:51 AM
rmarin2's Avatar
Question Side view mirror realignment
Anyone know how to realign the passenger side view mirror? The housing is fine but the glass was knocked out of position when someone hit it. The mirror folded in and the glass came loose. I can secure the glass back but it is out of alignment. Any suggestions?
Thanks!
-Rich
Old 07-13-2002, 12:15 PM
On the way!
fla-tls's Avatar
Can't you compensate for that by adjusting it?
Old 07-13-2002, 12:38 PM
rmarin2's Avatar
No, because if you use the memo feature, the mirror would turn to the stored position but because it wasn't aligned it would just keep clicking, as if its trying to force the mirror into the correct position.
UPDATE: I fixed it but not exactly sure what I did. I used the drivers side mirror as a guide. I moved the drivers side mirror all the way in and then all the way down. I then forced the passenger side mirror all the way in and then down. It works normal now!! No clicking and it auto-tilts normal again!!
Old 10-02-2002, 02:33 AM
jpeart0's Avatar
Has anyone experienced a failure in the auto-tilt function with the left side mirror. Mine has finally bit the dust. It was intermittent for a while while putting tranny in reverse. Sometimes it would adjust and other times nothing. Now nothing happens.
Old 10-02-2002, 03:02 AM
...and then there was One
SimTypeS's Avatar
I would say to take it to the dealer. It is "defective", right.
Old 10-02-2002, 07:30 AM
vlam's Avatar
jpeart0: You probably know this already but do you have the passenger side mirror adjuster selected?
Old 10-02-2002, 11:00 AM
snapple's Avatar
When you park does the driver side mirror also tilt while parking? I never noticed it.
Old 10-02-2002, 02:46 PM
pianoman41's Avatar
I think you mean the passenger side mirror, right? Make sure the mirror selector switch on the driver's door is in the center position. If you leave it in the right or left position the mirror will *not* tilt down in reverse. It will only tilt down with the switch in the center (hence, the icon under the center of the mirror switch that has a mirror with a "down" arrow underneath).
Old 10-02-2002, 02:47 PM
pianoman41's Avatar
Nope, just the passenger side mirror.
Old 10-07-2002, 09:30 PM
jpeart0's Avatar
Pianoman41,
Thanks for the tip. I will check the switch position. I did mean the passenger side mirror. Sorry for the confusion. I will let you know if I have mistakenly left the switch in the wrong position.
Old 10-07-2002, 09:45 PM
jpeart0's Avatar
Just checked my mirror adjustment switch and YES it was set to the passenger side for adjustment. Kiss this off to OPERATOR error. Thanks again Pianoman41! I feel a bit foolish but hey you saved me the embarrassment of finding out at the dealer. It works fine in the middle position.
Old 10-08-2002, 08:51 AM
pianoman41's Avatar
No problem. That's what this site is here for....
BoricuaTL
04-08-2016 01:08 PM
guitarplayer16
11-29-2015 02:03 PM
Rocktman1
10-31-2015 02:33 PM
09-17-2015 10:16 AM
dre707
09-08-2015 08:32 PM
Quick Reply: Side view mirror realignment
