Should I be capable check for proper installation of led with continuity at voltmeter
There is problem when you try to install Led bulb in standard dash regard direction. Can I use continuity at voltmeter to check if led bulb is properly installed rather than connect power to dash to see if bulb is lighting?
Just flip it if one direction doesn't work.
