shock sensors and WARN away car alarm feature
I got my car broken into a couple months ago and i don't want it to happen again.
I also don't want to spend so much money on a Clifford Avantguard that has 100000000 functions that are totally unecessary, in my opinion.
I am going to add shock sensors to my factory alarm
I need the WARN AWAY feature as well. Is there ANY way to get this feature as well without having to buy a brand new aftermarket alarm?
You could always use the warn-away wire to connect to a relay that activates the horn (or any other siren that you decide to add) directly. Just make sure that the relay is only powered when the alarm system is armed. To do this, you'd have to tap into a wire that is activated only when the alarm system is armed (such as the blinking led). If someone has a Helm electrical manual, he might be able to direct you to an easily accessible underdash wire to tap into.
actually you can buy a shocksensor online(forgot where, but i'll find it) and have it hooked up to a aftermarket siren so at the first stage it'll chirp the siren and at 2nd stage it'll trigger the horns/hid (factory alarm) I think the sirens are less than 20 bucks and the sensor are also less than 20.
Oakes
Wash & Wax
10-12-2015 11:17 AM
