Service Question????
I have an '03 TL-S with 10,034 miles. My service light just went on. Does anyone know what type of service is needed at this milage. Do I need to go or can I just clear error and go on with my life. I tried to call the dealership to find out, but they said "they have to assess the job first" (meaning they want to rip me off). What do you guys think??
Your owners manual describes the maint recommended per interval.
I personally use that as a guide for when I need to perform certain maint functions. I find it better and more cost effective than the stealership.
are you talking the checkengine light or the Maintanance required light?
If its the main req light it means Nothing. Its a dummy light thats supposed to be reset every oil change and be a reminder when to change oil
its ONLY a dummy light. nothig to worry about. There is more abou it in your manual.
you hold the trip and reset buttons in THEN while holding them in turn the key to the run position (2 clicks on the key) and KEEP holding the 2 buttons in till the light turns off (about 10 seconds) if you turn the key and then push the buttons in you will mess with the outside temp readout
