Seafoam helps to increase MPG?
NEVER add seafoam to a TL brake booster line!!!!!
USE only the correct ports- master vac at TB assembly or thru TB air inlet
BEST WAY is 1 can in fuel thru just under half tank/8 gallon in gas tank- do that 2 times, and clean TB air plate separately
that is direct from seafoams head tech guy!
Many of those honda vids are irrelevant to the TL- different systems
for 1st seafoaming= do the 2 cans method, after that at midyear/oil change time- 1 can thru 1/2 to nearly full tank as a maintenance dose.
At start of next `year` do the 2 cans method as the annual cleaning doseage
Fuel is a good cleaner on its own. If you would like to get a cleaning, I would recommend going to a shop and getting a BG cleaning.
https://www.bgprod.com/
Car X performs these. The car is put on a machine that uses a drip to inject the cleaner.
I've used seafoam on other cars and it never made a big difference. Intake plenum cleanings make a difference. No cleaner will make a night and day difference but they can help, again, when using something that is effective and with the proper equipment.
