rotors
rotors
is it me or are acura oem rotors the biggest piece of craps out there? they warped so I got them cut , 2 months later warped again. will aftermarket rotors do this also?
oem rotors sucks. warping depends on envi and driving habit and how much you drive....but 2 months........that totally sucks. Mine really started to show after 42k miles, had them resurfaced, 44k and they are warped again.....2k.........I don't put that much stress on my brakes either.....I'll learn to live with my steering wheel shaking rather then spend that much cash again.....aftermarkets depends on what type and what brand, but I'll bet way better then OEM rotors
Retired MOD
1 Post
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Just so you know. The aftermarket rotors warped just as easy as the stock rotors. Actually a little better than stock, but nothing worth the money.
I have tried 3 different rotors 4 different pads and 2 different calipers and they still warped.
- I had KVR crossdrilled "current" (the best so far, but they also warped)
- I forgot the name, but they were also crossdrilled.
- Stock rotors
- Stock semi-metallic pads
- Acura organics pads
- Axxis semi-metallic pads
- Wagner Organics pads "current"
I had the stock 1-piston calipers and now I have Legend 2-piston calipers.
I also have Steel braided brake lines
With all that and different configurations, the brakes still get warped.
So I come to beleive that unless you fully upgrade the brake system to like brembo 13" with 4 piston calipers or take some weight from the front or redisign the freaking break system.
So don't hope aftermarket parts would help you much, so don't waste your money.
- Stock rotors
The whole problem with pads and rotors is the right combination of both. Thing is pretty simple, friction material on brake pads that is too hard for a given rotors will warp them of course. It is relatively easy to make pads with hard friction material and to claim lifetime warranty on them if you do not care about rotors. And that is exactly what happens, you can hear it everywhere, they offer lifetime warranty on pads and shoes but they never ever mention rotors. But it is not that easy to make long lasting pads that are not going to affect rotors and that is the whole trick. Also, machining rotors (making them flat) relatively early (after say 20K or 30K or even 40K miles) is usually not worth, that only means that you have wrong combination of pads and rotors. By machining them, they become thinner, which means they can accept less heat, which means making them even less durable. It does make sense if they have long mileage. In general, the heavier the rotors the more durable they are going to be. And the way you drive can make the life of your rotors/pads shorter or longer but in my opinion it is completely negligible.
In regards to aftermarket brakes I think that Raybestos makes good pads/rotors for decent price, so installing both can make sense but putting aftermarket pads on OEM rotors is not really a smart move. http://www.raybestos.com/
Is there any reason to order the Brembo's for $50 each from tire rack and pay for shipping, over just going into the autoparts store and walking out with Raybestos rotors?
Blown is Best
I'm planning on going with Cryogenic slotted rotors on the front when mine get bad. Here's some info on how it works.
http://www.policerotors.com/pub_info.htm
So far, I think it's the best solution short of going with a big brake kit.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
