Rim Swap
Hi Friends
I want your opinion I have 2 set of tire (All Season and winter tires) both on rim Detail are given below Summer tire Michelin Energy MXV4 Plus Tires (205 60 R16 91V) on Original Alloy rim (5x114.5 bolt, 16”x6.5”, hub bore 64.1 mm) Winter Tire Pirelli Winter Carving Egde (205 60 R16 96T) on MSW Rim (5x114.5 bolt, 16”x6.5”, hub bore 67.1 mm) My question is that if swap the rubber of winter tire to original alloy rim will it fit or it not gonna work that way Thanks Hee Dehis |
Same size rims, same size tires.. should swap just fine I would say...
Yeah, 205-60 R16 are the original equipment 16" sizing for tires.....which both summer and winter are the same basic 16" diameter size, therefore ya can swap the tires to the 16" rims as MrMoAcuraPar previously stated with no problems. But, if ya already have 4 summer tires on matching OEM alloys......consider leaving the spare winter tires on the other rims for convenience.
