Reverse Glow Gauge Install
Hey, I realize the DIY for this is no longer available. I've searched and got all the scraps of info for the most part.
I've taken 2 screws off from the panel above the speedo, and I've basically taken out the entire panel. I disconnected all of the wires/switches. However, the panel seems to be still attached at the steering wheel. Do I need to unscrew anything or just yank?
2000 acura tl FPR
that I'm not sure. I've never installed them. I'm probably going to have to go with one of these for my setups.
http://www.racepak.com/Components/Dash_Compare.php
Alright, after I got the new faces over the needles, I decided to test them before reassembling them. All the needles work well, but my SRS light is staying on. Any ideas as to why? I don't see why the SRS would be affected by messing with the cluster.
Hmm... I can't seem to be able to get the black covering back onto the speedo piece, because the cables are sticking out. Did you guys just cut/dremmel the plastic to fit? Doesn't seem that any of the three will fit without cutting through the plastic.
Also, I am selling my car and I am going to part out the Type-S speedometer with blue leds. Just plug and play so you don't have to go through all of this nonsense. PM me if you want it.
Rice Patrol
they're pretty cool
This is becoming a huge hassle, but I can't buy the TL-S speedo since I'm TL-P =[.
I'm basically done now, but my D5 light won't come on. Has anyone else experienced this? I took it apart, and the D5 light looks like it has a hole in the solder point, but I don't want to mess with it.
Also, my turn signals don't work, but I think that's because I haven't hooked up the other dash buttons (Emergency light button).
BoricuaTL
04-08-2016 01:08 PM
rockyboy
01-25-2016 06:00 PM
Mike Bertram
09-10-2015 09:27 AM
