retinted/new audio/need some help
all the stuff to be installed (minus the shoes)
wiring the amps
more wiring
after the tint was RE-done
more amp wiring
remote bass gain
now the issue... at mid to high volume the system sounds good but at low volume i'm getting a loud hissss. the installer said i need a better inline converter? he suggested a product by sound gate (link to product)
i also need to get a new sub, ideas?
wiring the amps
more wiring
more amp wiring
remote bass gain
that is pretty expensive - you need a good line output converter to feed your amps with a good RCA signal. If you use a cheep one, it will pick up noise and you will hear it from your speakers. that noise you hear is always there, just the music overpowers it when you turn it up. For a sub I suggest JL Audio. Get the W3V2 line and you will be very satisfied with the sound and bass output.
Originally Posted by Michelin Man
the installer said he could get the converter for $80 +install cost... should i look for something else?
i've had the same LOCs for several years and i haven't a clue what brand they are.
