Resetting ECU: The Long Way?
well most folks say disconnect the ecu after adding performance parts. a few people say, dont worry about it, the ecu will relearn on its own. if i do just drive and let the ecu adjust itself... how long does it take for it to completely take into affect?
i had a cai/exhaust, and i just installed xs headers 2days ago. but ive never reset the ecu.
I'm Down Right Fierce!
Give it two weeks.
I say after about 2-3 fill ups it should be ok. Try to give it some spirited driving after it's warmed up.
Yeah I reset my ECU when I installed my CAI and headers. But god... resetting the radio code was such a bitch I refused to do it again. Put in pulley and exhaust afterwards and didn't reset the ecu this time... in about week or so it was fine.
Originally Posted by BraveDemon
Give it two weeks.
If you have the card with all the codes go for it. I was told a code by the dealer, and it didn't work. I had to take apart the entire dash to get the serial number, called the dealer and they gave me the wrong code again. I was so fed up, I drove it down to the dealer and let them fix the problem.
If you have the code then go for it and reset the ECU.
I personally don't see the point as it messes up all of my settings in the car and the ECU will eventually get the new settings anyway.
BTW: Sweet Ass Anthracite. Love that color.
![Love](https://acurazine.com/forums/images/smilies/love.gif)
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
You can reset the ECU also by pulling the clock backup fuse
Odds are, the stock settings are on the conservative side, e.g., a mixture on the rich side, slightly retarded timing, no setting that could 'harm' the engine. As you drive, the sensors feed information to the ECU that improves performance. I imagine this information is kept in volatile memory, the kind that gets erased when the ECU loses power. Hence reports that performance improves x number of days after installing {fill in the name of the product} and resetting the ECU.
