resetting the ecu
Disconnecting the battery should reset the ecu and you will also lose your presets on the radio. Don't forget that you'll also need the radio code once you reconnect the battery. Not sure about the length of time but I would say about 5 minutes should do.
Originally posted by SSMAN66
The only way to be certain you clear the ECU is to disconnect both battery cables and touch them together.
