removing dash faceplate??
can anyone give me easy advice on removing my dashboard faceplate?? i'm having a major problem with dashboard vibrations, extremely loud ones.. i'd like to just get it open and see if there's stuff loose in there.. it's ridiculous how bad it is.. maybe put some soft padding in there to cut it out.. anyone with any insight on this? i can remove the two screws at the gauges, and the ones behind the steering wheel, what else do i do??
After removing those 2 top screws the piece should snap off. Take a flathead screwdriver and wrap it in something soft so you dont damage the dash.. The corner where the fog light switch is start there. Just start pulling it towards you. The whole things snaps off..
Its not that hard. If you want remove the panel underneath the steering wheel and put ur hand back there and push it out...
dainmezron
10-16-2015 06:56 PM
