Remove paint scuff from bumper?
3rd Gear
Backed out of my garage this morning and grazed the front right corner of my bumper against the powder-coated aluminum flashing of my garage. Doh! How should I remove this paint scuff w/o making things worse with paint swirls, removing clear coat, etc.?
Dragging knees in
Turtle Wax Rubbing Compound only if it's just scuffed. If you have any reason to believe that it's deeper than just a scuff, you need to take it to a body shop. Otherwise, the Rubbing Compound will do magic.
I did the exact same thing with my Tahoe once, and the Rubbing Compound took care of it. Give it a try. It's about 4-5 bucks, and it comes with so much that you could use it for the rest of your life.
all good suggestions
try a wax first hand applied with a terry cloth towel (terry is more aggressive than foam) -
if that does not work move up to a rubbing compound and as the other posters have stated - be sure to wax afterwards.
I was thinking Clay
since it gets overspray off - but I think a paint deposit like that (overspray isn't really "forced on the paint like a scuff ) would require a little more aggresive approach -
but clay would be THE least aggresive
Originally posted by NsX Pilot
dont forget to wash n wax it after.....always remember start with something that is not too abrasive and work your way up... i would try the 3m fine scratch remover first and then work my way up to compound.....and always wax it after.
3rd Gear
Originally posted by fsttyms1
being a painter myself i would recomend NsX Pilot's method first. if that doesnt work then i would use like a 1500 - 2000 grit wet sand paper and then follow his steps again
Originally posted by vsop TL-S
well I can only see that you might need to wet sand and buff out, but that is up to you.
try this link!
http://www.meguiars.com/store_meguia...&subcatagory=2
also check out the how to center, they have pretty good videos on detailing and buffing and wetsanding
Oakes
Wash & Wax
10-12-2015 11:17 AM
09-17-2015 09:01 PM
