Recall item for all 2002 TL and TL-S
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
I found out about a possible problem with the driver side window control box. Acura has sent a recall fix for the part to all dealers to replace the control box with a new one. Seems that during the making of these window control units, moister might have been allowed in, causing the componets to possible coirode and fail. Just go to your dealer to get it fixed, .4 hours is the alloted time for the install. Hope this info helps you all.
Cedric
2002 Agean Blue TL-S
Cedric
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Thanks, but we already knew ![](http://www.acura-tl.com/ubb/wink.gif)
See link below.
2002 TL Power window recall
From Wayne Gruen. Service Manager at Park Ave Acura in NJ.
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank>
</A>
See link below.
![](http://www.adamoski.com/images/Acura3200.jpg)
I remember the last time I brought my 95 Prelude in when it was 2 months old to replace an in-door power lock assembly and I ended up needing the whole door repainted! The technician missed with his screwdriver and poked a dimple out from the inside. When I complained to the service advisor, he had the nerve to ask if it had been there before!!! From the inside! Just be careful and inspect the interior panels and door skin when you get your car back. Or the other option is to bring it in only when it fails.
Not a Blowhole
It is no big deal to r and r the door panel. I would not worry - look how little time is allocated - they might not even need to pull it.
I wonder if this problenm explains why whe thw window is cracked, I can feel air rushing past my hand from the switches when I went to adjust. I'll bet some sort of gasket was either pinched or designed or mfd. wrong.
Rage On!
2002 TL-S w. Comptech header/exhaust
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Rage On!
SSR Integral A2's
17x7 45mm offset
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
