recall info
WhizzBomb
all right here
Bulletins for 1999 Acura TL V6-3206cc 3.2L SOHC MFI
Safety Recalls
TSB Number Issue Date TSB Title
1. 03-034 JAN 04 Recall - Ignition Switch Key Interlock Repair
2. 03-034 JAN 04 Recall - Ignition Switch Key Interlock Replacement
3. 02-014 JUN 02 Recall - Ignition Switch Replacement
Emissions Recalls
1. 00-004 DEC 01 Recall - DTC P0401 or P1491/EGR Port Clogging
2. 00-004 AUG 00 Recall - Emissions Product Update
General Recalls
1. 02-027 SEP 03 Campaign - Automatic Transmission Defect
Service Bulletins
1. 01-041 FEB 04 Engine - V6 Engine Oil Leaks
2. 04-004 FEB 04 Computers/Controls - HIM Module Updating
3. 01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
4. 03-027 NOV 03 Emissions - MIL ON/DTC P0420 (Catalyst Efficiency)
5. 00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
6. 03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
7. 91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
8. 03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
9. 98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
10. 97-040 MAY 03 Keyless Entry - Description/Identification/Programming
11. 01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
12. 00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
13. 03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
14. 03-006 MAR 03 Engine Controls - Idle Speed Inspection
15. 03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
16. 03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
17. 02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
18. 02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
19. 02-006 MAR 02 Front Seat Back Panel - Loose/Detached
20. 02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
21. 98-023 DEC 01 Instruments - Navigation System Setup During PDI
22. 96-025 DEC 01 Navigation System - Component Exchange Program
23. 01-005 DEC 01 Power Steering Pump - Noise
24. 99-051 AUG 01 Exhaust - Muffler Paint Peeling
25. 00-037 AUG 01 Brake Disc - Refinishing Guidelines
26. 01-004 JUL 01 Wipers - Smear or Streak the Windshield
27. 01-003 JAN 01 Alarm System - Sounds By Itself Intermittently
28. 00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
29. 00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal
30. 00-025 AUG 00 Body - Windshield Molding Deformed
31. 87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
32. 00-018 JUN 00 Door Switch - Squeaks
33. 00-016 MAY 00 Door Mirror - Vibration
34. 00-015 APR 00 Accessory Moonroof Visor - Creaking Noise
35. 00-014 APR 00 Squeek or Creak From Driver's Seat
36. 00-008 MAR 00 Torque Converter Oil Seal Installation Tool
37. 98-037 FEB 00 Brakes/Traction Control - ABS/TCS Lamp ON/DTC's Set
38. 00-002 FEB 00 Rear Door Sash Trim is Wrinkled
39. 98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
40. 99-040 OCT 99 Troubleshooting DTC P1456 and P1457
41. 96-025 SEP 99 Navigation System Exchange Program
42. 99-035 SEP 99 Squeaking Noise From The Rear Console
43. 99-042 SEP 99 CD Tray WIll Not Stay Closed
44. 99-039 AUG 99 DTC's P1456 & P1457 - Diagnosis/Troubleshooting
45. 99-036 AUG 99 Fuel Gauge - Inaccurate
46. 99-037 AUG 99 Keyless Entry Does Not Work In Certain Areas
47. 99-008 JUN 99 Navigation System Locks Up or Resets
48. 86-014 JUN 99 Brakes - Brake Disc Refinishing Guidelines
49. 90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
50. 99-013 APR 99 A/C - Popping Noise From Center Vent
51. 99-012 MAR 99 Security System - Sounds When Not Armed
52. 99-007 FEB 99 Glove Box - Light From Glove Box When Headlights ON
53. 92-009 FEB 99 Drivetrain - Creaking Noise While Turning
54. 99-005 JAN 99 Paint - Codes/Cross References
55. 98-034 DEC 98 Security Horn Sounds Weak
56. 98-035 DEC 98 Steering Wheel - Noise When Turning
57. 98-004 APR 98 Audio Unit Anti-Theft Labels
58. 98-005 APR 98 CV Joint Boots - New Band & Tool
59. 98-022 FEB 98 TQI & New Model Information
60. 90-009 DEC 97 A/T - Warranty Exchange Program
61. 87-015 NOV 97 Audio Unit In-Warranty Exchange/Out-of Warranty Repair.
62. 90-010 OCT 97 Audio Unit Error Codes
63. 86-014 MAY 97 Brake Disc Refinishing.
64. 97-013 MAY 97 New Halogen Leak Detector
65. 97-010 MAR 97 New Fuel Pressure Gauge and Replacement Parts
66. 97-009 MAR 97 A/T Oil Pressure Testing Tools Update
67. 97-001 FEB 97 SRS - Do it Yourself (Owner) 10 Year Inspection
68. 96-039 SEP 96 Power Steering Pressure Gauge
69. 92036 NOV 92 Vehicle Fails State Inspection Emissions Test
Safety Recalls
Emissions Recalls
General Recalls
Service Bulletins
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
