Re-wire fog mod help!
Ok, I bought the wiring splicer (3M Trailer Light Tap Connects "For use with 18-1 gauge wire) .. Is this the right wiring splicer? Do I remove the White/Red & Red/Black wiring from the prong? How do I insert the wiring into the wiring splicer? If anyone has any pics on how to re-wire your fogs...I'd greatly appreciate it!
I had a friend (who does alarm installs) do mine using the instructions linked below:
http://www.acura-tl.com/faq/faq.php#5c
Make sure you can see through both sides of the connector from one end to the other, like two small tubes joined together in the center. Then take a sharp razor knife and *carefully* cut the plastic in the center so that it opens like a clamshell. Then you can take the two wires and slide them in through the open side so that one wire ends up inside each "tube", side by side. Then you just crimp down on the connector and the internal blade will bite into both wires and make the connection.
Take it to a local Audio shop and drop the guy a twenty, and he`ll take care of it for you, at least it will be done right with out shorting out your wiring harness!!!!!!!!!!!!!
InFaMouSLink
10-27-2015 06:52 PM
