Radio Code did not work.
I just purchased a used 2003 TL Type-S. The radio was locked and needed the security code. I contacted the delear for the code which they gave me. And it did not work instead I have an error now saying ErrE. It wont allow me to retry the number. What would be my options now.
wait a bit, and try unplugging the antenna fro the back then entering the code. Yes sounds weird but mant have had to do that
Also Do i have to do the code with the car in the on position or can it be running.
Radio code
Hello all,
I recently reset the radio code on my 03 TLS too. Here is how I got my to work.
1. Obtained valid radio code (5 digits)
2. Turn ignition key to the on position, and turn radio on
3. Enter key code
IF, there is still error, tried again.
Verified with the dealer, perhaps they giving you an invalid code.
HTH
Regards
3. Enter key code
HTH
Regards
Originally Posted by s24
How do you get the radio out to remove the antenna plug?
I would just turn the key to the run position.
Another Solution Which Happened To Me Is That If You Disconnect The Battery For About 2mins And Then Reconnect And Try It It Should Work. When My Car Was Gettign Worked On The Code Didnt Work Initially Then A Delaer Friend Told Me To Disconnec The Battery
And Viola It Workd
And Viola It Workd
Hate to revive an old thread, just tried this and it worked like a charm, spent all day frustrating myself putting in my radio code and waiting for the error to clear, took 10 mins, and it worked...
dirleton
08-06-2024 08:19 PM
Jamus22
06-11-2023 10:08 AM
