Quick Trans Fluid Changing Question..
Old Feb 1, 2011 | 09:43 AM
marcelft's Avatar
Ok..I've been reading up, saw the trans fluid change DYI, but not sure what is meant by the 3 x 3, or 1 x 3?
Old Feb 1, 2011 | 10:25 AM
01tl4tl's Avatar
1x3 = 1 drain and refill with 3 qts
3x3 = 3 sets of drain and refill with 3 qts each time for full fluid changeout
not a great plan on already high miles and never changed fluid-
stick with a 1x3 for safety
use honda atf
Old Feb 1, 2011 | 10:43 AM
marcelft's Avatar
Ahhh...makes sense now. TY. I just bought the car (99 TL) from a friend. The trans was rebuilt 1.5 years ago by a shop that Acura subs out tranny rebuilds too, so not worried about never replaced fluid. My concern is that I feel a slight hesitating, possible slipping between 1-2. I saw I Hate Cars rave about Redline Type F, thought I'd give it a try. But doing a 3 x 3 with Redline would cost a pretty penny.
Old Feb 1, 2011 | 01:46 PM
acutee's Avatar
Should try the cheap Type F first, and if it is all, then change it over with Redline.
Old Feb 1, 2011 | 04:50 PM
01tl4tl's Avatar
note: 3 is actually 3.3-3.4 qts will drain out if fluid warm and you let it drip till done
Old Feb 1, 2011 | 05:27 PM
marcelft's Avatar
Ok, makes sense to use cheeper fist just in case, but now Im getting confused. When i Google Type F ATF, it says it's for Ford cars? Is that right?
And thanks for the heads up on the amount that drains, would suck if i were to only buy 3 quarts, and not have enough to fill.
Old Feb 2, 2011 | 05:57 AM
01tl4tl's Avatar
from back in the day: there were two main atfs-
Dextron3 (bad for us) and used by most car makes of the time
and Type F, used in fords --probably under the keep it simple theory for oil change places--F = ford fluid
Its used in many other cars as well- saturns use it~
Old Feb 2, 2011 | 06:27 AM
marcelft's Avatar
Sweet, I learn something new everyday. I usually have manual cars so automatics are new territory for me. Thanks.
mada51589
Jan 9, 2025 04:40 PM
Aleax
Sep 11, 2015 11:31 AM
nash3222
Sep 10, 2015 09:46 PM
jfman55
Sep 5, 2015 02:55 PM
