Quick oil change help!
There's no Acura in
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Hey I'm in the process of trying to do an oil change but I noticed this yellow hardened goo on the drain plug and the bolt won't come off unless I turn it super hard! I thought the bolt was just supposed to be on there "snuggly" but should I just turn it as much as possible until it's loosened?
I'm putting in 5w-30 synthetic castrol.
Chapter Leader (Central Florida)
The yellow hardened goo is something oil shops use to show that the plug hasnt been loosened in between oil changes in case someone comes in with a complaint. Often times shops are stupid enough to use pneumatic tools and they can strip the plug. Id run to a local car store and pick up a replacement plug and gasket just in case.
There's no Acura in
Thanks LostSol; so it's safe for me to just turn it hard as heck? I just didn't know if that stuff indicated if there was a leak or the oil pan threads are bad or some other issue.
Well theres only one way to get it out and that is to turn like it a s.o.b. However if it gets to the point of being scary tough, you may have a stripped pan and might want to consider taking it to a shop to do it, they may have to rethread your pan. Thats the exact reason why I started changing my oil myself. Stupid oil shops.
There's no Acura in
Nope...I just have:
- 16mm ratchet
- 7.5qt oil drain pan
- 5qt 5w-30 castrol synthetic
Thing is, if I do need anything I can run to AutoZone but if so I need to go before they close. Is a oil pan plug gasket something I need?
- 16mm ratchet
There's no Acura in
I'm turning it to the left...e.g., away from the right wheel. And this is the first time I've used a jack/jackstands (no woodblocks though) so I don't wanna go crazy and have the car fall on me!
There's no Acura in
That's very possible...I read some thread where it said you need a 17mm...so that's what I initially had but was too big for the bolt....which makes me wonder if the plug is actually "glued" to the pan!
I'll try some tapping right now.
I think youre turning it the wrong way, if your wrench is pointing down and you are facing the plug, you should be turning the plug towards the right wheel
There's no Acura in
Thanks for all the help....I got it off! Just had to turn it as hard as I really could (e.g., disregarding my safety). I was turning it the correct way...just didn't do a good job of describing it correctly (my interpretation of "to the left" meant towards the left-wheel/away from right wheel...but if you think about it, a turning motion actually describes both depending on what point of the circle you're on).
Only bad thing is that I dropped the bolt in the oil drain pan....and now I gotta fish it out when it's done draining.
There's no Acura in
Yeah probably a good idea to grab a 17mm drain plug when I drop off my oil @ AutoZone...and I'll make sure that it's on there snuggly (w/o leaking).
lol, my first oil change....I know you guys are laughing but hey, everyone has a first time!
Not laughing at all. Always better to ask for help then to do it yourself without knowledge. This forum has saved my ass numerous times.
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
HydrasunGQ
09-14-2015 10:14 PM
