Quick NGK question....
Old 05-01-2007, 04:30 PM
dnd2984's Avatar
Lightbulb Quick NGK question....
Ok just got back from advanced auto parts...and need to go back in a hour..
Ok what NGK plugs should I get here is the break down
for 9.96 they have what is called OE he said they have 4 times more platnium than other plugs
Then the Iridium for 6.98, he said these are a lower level than OE but arnet these the ones everyone is using??/
SO what should I get???
Old 05-01-2007, 04:32 PM
dnd2984's Avatar
see if this helps
http://www.ngk.com/results_app.asp?AAIA=1370719
Old 05-01-2007, 05:46 PM
dnd2984's Avatar
anyone i need to go pick these up tonight
Old 05-01-2007, 06:22 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Stick with the OE plug
J32-A1
NGK- PZFR5E-11
J32-A2
NGK- PZFR6E-11
Old 05-01-2007, 06:46 PM
dnd2984's Avatar
Also is there anything else that is better than NGK plugs?
Old 05-01-2007, 07:34 PM
dnd2984's Avatar
Kris how long should it take me to change them out. Its finals week and I will be doing them when I take a break.
Old 05-01-2007, 07:44 PM
fsttyms1's Avatar
Nothing is better.
a hour to a hour and a half for a novice. 30 min or less for someone who has done it before.
Old 05-01-2007, 07:55 PM
dnd2984's Avatar
Originally Posted by fsttyms1
Nothing is better.
Thank you sir.
Any tips??
Old 05-01-2007, 08:00 PM
fsttyms1's Avatar
for teh rears get a old blanket or a big towel so that you can lay on the engine to access teh rears easier
Old 05-01-2007, 08:55 PM
dnd2984's Avatar
Ummm I am kinda on the heavy side will it be safe for the engine
Old 05-02-2007, 01:21 PM
2003.2tl's Avatar
im on the heavy side as well
took me about 30 min to do it....the rears are a bitch....especially the one right under the strut bar
Its on the LEFT if you are facing the engine from the front of the car...use an extension for those ones....good luck!
Old 05-02-2007, 01:22 PM
2003.2tl's Avatar
im on the heavy side as well and i just leaned on the body a little...
Old 05-02-2007, 01:47 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
make a 9 inch extension for the socket to do the rears- fits perfect
The NGK is the best brand for our cars and last longest
you wont want to do this job again for a long time!
MANY of us use the new hi tech metal- IRIDIUM- 7 bucks each
some stay with older technology= Platinum
personal choice
Do not gap or touch the plugs except to put a little anti sieze on the threads
Old 05-02-2007, 02:39 PM
No He Can't
6MTUA5's Avatar
Here's another thread about installing them
Old 05-02-2007, 03:58 PM
fsttyms1's Avatar
It will be safer on that than a fender
Old 05-02-2007, 07:18 PM
dnd2984's Avatar
I got the plug and everything to go with them will be changing them out tommorow...
Old 05-02-2007, 07:39 PM
dnd2984's Avatar
Is there a certain they need to be installed? Or just put them in and screw them in?
Old 05-02-2007, 07:47 PM
fsttyms1's Avatar
nothing specific. All you need is a allen wrench to remove teh coil pack and to remove the plastic engine covers. (type-s owners it helps to remove teh 2nd stage actuator)
Old 05-02-2007, 07:50 PM
01tl4tl's Avatar
YES very important
Lefty loosie
Righty tighty
Thats as you look directly at them
Use a torque wrench or carefully install by feel to makers spec
Old 05-02-2007, 08:22 PM
dnd2984's Avatar
I really hope this solves the rough idle. When I am in D5 at the light stopped my idle is really rough.
Old 05-02-2007, 08:43 PM
fsttyms1's Avatar
Change your mounts lately? Clean the EGR and the IAC? and TB out?
Old 05-02-2007, 08:48 PM
01tl4tl's Avatar
kris
I have sprayed my TB a few times and I know there are threads on egr clean
What is the IAC- and how to clean??
My car runs fine but you know I am always looking for a little more
Old 05-02-2007, 08:52 PM
fsttyms1's Avatar
Originally Posted by 01tl4tl
kris
IAC is Idle Air Control valve. Its located on the bottom of the TB and is held on with just 2 screws. It gets carbon buildup and causes bad idle. Just take it off and clean it, then put a dab of wd40 on it to keep it lubed slightly.
Old 05-02-2007, 09:01 PM
01tl4tl's Avatar
Thanks Kris
Another DIY just for preventative maitenance!!!
My problem is: one neighbor comes over every time I have the hood up and says "why are you working on that brand new car!" (its a 2001-clean) and the other neighbor comes over with metal polish and buffs out my intake manifold! While it is looking pretty cool......lol
its funny that my TL has become the focal point on a block with a Lotus and MBz and Bmrs and motorhomes and boats etc.
Just my plain jane stealth TL
suckering tailgaters way too deep into a corner heheheh
Some cars turn about as well as a jet-boat
Old 05-02-2007, 09:21 PM
dnd2984's Avatar
Got all new engine mounts when the tranny was replaced in Dec. Does seafoam count for cleaning the EGR.
pics of IAC
Also I was takin a break from studying wonderful Financial Statements for my test, and went to go mess around under the hood. Holy god the coil pack is long. Can I access the back without much trouble?
Old 05-02-2007, 09:24 PM
dnd2984's Avatar
Thats because the 01TL is a sexier car than those bmers and mercss
Thanks Kris
Old 05-02-2007, 09:27 PM
dnd2984's Avatar
Talking
Kris i think it would be a wise investment if I just flew you done to sunny FL to solve all my TLs needs. I have plenty of beer in the fridge, and tons of college hotties around here....
Old 05-02-2007, 10:27 PM
dnd2984's Avatar
So I got bored and did the front 3 plugs. It only took about 10mins. I guess the rears must be a big big bitch then... BUT look at the pics of the old ones. I dipped the other one in seafoam just to see how well it will break down the carbon. The pic is big so u can see the details of a dirty ass sparkplug with 95k miles.
Old 05-02-2007, 10:28 PM
dnd2984's Avatar
Wait are they that dirty becasue in the last 1.5 month I sea foamed 3 times to really clean everything out???
Old 05-03-2007, 09:54 AM
dnd2984's Avatar
Can the car be used with 3 new plugs and 3 old plugs?
Old 05-03-2007, 10:19 AM
dnd2984's Avatar
http://www.centuryperformance.com/spark2.asp
Old 05-03-2007, 10:39 AM
cjde2006's Avatar
Would you put in 3 new quarts of oil and 2 used?
Old 05-03-2007, 11:28 AM
01tl4tl's Avatar
Do you have any issue with oil burning/consumption
My plugs were greyish like they are supposed to be, except the center plug on each side was slightly darker
Those look wet!
Old 05-03-2007, 11:43 AM
dnd2984's Avatar
Those look wet!
Not that I know of...Cna this lead to a huge issue????
Old 05-03-2007, 12:56 PM
01tl4tl's Avatar
If your not using any oil- I am just an alarmist- sorry
Check the engine oil now and then between changes.
Pics can be deceptive
Did you do the 20 minute high rev drive after seafoam?
Pull a front plug in 1000 miles and check its color
Why front? - because their easy to reach!
Old 05-03-2007, 01:20 PM
fsttyms1's Avatar
pics of IAC
No seafoaming doesnt count for cleaning the EGR. The intake needs to be removed and hand cleaned.
Yes rears can be accessed without much trouble. Just need to lay over the motor
Old 05-03-2007, 01:22 PM
fsttyms1's Avatar
Those plugs look fine. They just look old.
Change out all 6, the rears arent any harder, just takes a bit more time cause of having to reach over the motor.
Old 05-03-2007, 02:30 PM
cjde2006's Avatar
is there a DIY for cleaning the intake?
Old 05-03-2007, 02:31 PM
cjde2006's Avatar
sorry...meant EGR
Old 05-03-2007, 02:44 PM
01tl4tl's Avatar
yes many threads with pics search EGR
Its just bolts and 3 cans of carb cleaner
May want to install a thermoblock spacer while you have it all apart
Thanks Kris- I thought they may be just really old but always want the owners to keep a close eye on their car. My plugs looked different- but the prior owner may have had them replaced at the dealer early.
Quick Reply: Quick NGK question....
