Question on transmission failures.
6G TLX-S
Page 522
Clutch Q/A while Shifting
Table with temp rise and other stats for WOT second-to-third, WOT third-to-second (kick-down), and closed throttle 5-to-3 MANUAL downshift.
ON WOT 2-to-3 upshift, the delta T was 100 degrees (assume C)
ON WOT 3-to-2 downshift, the delta T was 23 degrees
ON Closed throttle 5-to-3 manual downshift, the delta T was 111 degrees.
“* Clutch Q/A is not too high and is judged to be at acceptable level.”
Can someone explain what the heck is "closed throttle 5-to-3 manual downshift" ? I thought the auto box will downshift from 5-4-3 by itself when the SS is tapped back twice manually.
BoricuaTL
04-08-2016 01:08 PM
