question for the dropped/slammed tl's
Old Jan 17, 2011 | 01:02 AM
dc2kid's Avatar
hey guys, i just installed my ingals camber kit with the adjustable balljoint for the front and i got my alignment done, but the car is knocking on bumps i know it has to be the ingalls because it never made that noise with the stock upper control arm. does anyone have this problem or know how to fix it, i saw on the cl side one guy cut a hole but i dont want to do that and i dont want to raise my car up i saw a couple of tl's with the same drop on this forum so can you guys let me know what you did its a 99 tl and it has a finger gap in the front or just enough for the wheels to turn
thanks
Old Jan 17, 2011 | 01:33 AM
friesm2000's Avatar
B A N N E D
do you mean richard parker for the hole then...
as far as what you can do, not a whole lot without cutting or raising it up
Old Jan 17, 2011 | 10:23 AM
xtremex626's Avatar
Regional Coordinator (SoCal)
i have the same exact problem lol.. why dont people check problems and fixes?
my tire hits uca and i am slammed as well. its annoying and not music to my ears but yeah.. you have to either raise it or cut a hole so the uca can pass through and not hit the wall. i can barely make a turn! rubs when i try and make a full turn.
i'm not raising my car. gonna leave it the way it is.
Old Jan 31, 2011 | 11:34 PM
RicanTL99's Avatar
i have stock control arms with spc ball joint camber kits on the front and i have the same exact problem and just ordered the ingalls control arm with ball joint hoping i would solve this problem, and from the look of this post thats not going to be the case. should i cancel and just make the holes? lowering the car looks so good but hurts the pockets and everytime i hear that bang every bone in my body tenses up.
Old Jan 31, 2011 | 11:35 PM
xtremex626's Avatar
myeh.. get used to it.. part of daily slammed driving
Old Jan 31, 2011 | 11:41 PM
RicanTL99's Avatar
yeahh and to top it of i living in RI for the moment nd this snow and potholes arent helping. so im thinking of caneling the order i placed just this morning and spending it on something a little more enjoying seeing its just going to be the same problem
Old Jan 31, 2011 | 11:42 PM
friesm2000's Avatar
B A N N E D
i have them, and they need a bit of trimming also for maximum travel, but 95% of that is on the arm itself though, with only a little on the body (but not enough to go through though); they designed them a bit too "wide" for our strut towers (and part of that is because of the "wider" mounting area for the ball joint)
basically i got them trimmed enough now, where the shock itself actually bottoms out before the arm hits anywhere
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
