Question about Inspire taillights??
I am going to be getting a pair of used inspire taillights.....should I get the harness and bulbs that Tim sells with the 2002 tails?? Would that make it an easier and cleaner install? If I don't get the harnesses, do the bulbs just transfer from the stock tails to the inspire tails??
Thanks!!
Thanks!!
¤ Club Inspire ¤
I would get the harness, only a little bit more of cash. And yes, it would look cleaner from the inside. well, you have covers anyway. But the reason being is the Inspire/02 tails have a bigger bulb socket opening, thus the 99-01's don't fit right, people on this board used tape. But I figure water would get in and condense.
But, this is a two way street. It will work with the 99-01 harness. But IMO, I'd ge the 02 harness.
I've had my inpires on my 2000 TL for about 6 months now.
No water is sitting in my trunk nor in my lights
I ended up wrapping ports with electrical tape to seal the small opening for the turn signal ports
As far as I'm concerned the Inspires are as good out of the box.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
